Anilam G Code List for CNC machinists who work on CNC lathe machines with Anilam CNC controls like 4200T
More than one G-code may be specified per block.
If a block contains conflicting G-codes, an error message appears.
4200T CNC Controls for Turning
Anilam G Codes – Preparatory Functions
G-Code Function
G0 Positioning – Rapid Traverse
G1 Linear Interpolation
G2 Circular Interpolation – CW
G3 Circular Interpolation – CCW
G4 Dwell
G5 Ellipse
G9 Exact Stop Check
G22 Stored Stroke Limit ON (Programmable Stroke Limit)
G24 Spindle Speed Clamp
G31 Probe Move
G33 Threading
G40 Tool Tip Radius Compensation, Cancel
G41 Tool Tip Radius Compensation, Left of Path
G42 Tool Tip Radius Compensation, Right of Path
G53 Work Coordinate System (1-99,select)
G59 Modal Corner Rounding
G60 Modal Corner Rounding Off
G61 Exact Stop Check Mode (Continuous Path OFF)
G64 Cutting Mode (Continuous Path ON)
G65 User Macro Single Call
G66 User Macro Modal Call
G67 User Macro Modal Call Cancel
G68 Coordinate System Rotation
G70 Inch Programming
G71 MM Programming
G72 Axis Scaling
G74 Area Clearance (Face) Cycle
G76 Rough Turning / Boring Cycle
G77 Rough Facing Cycle
G78 Peck Drill Cycle
G79 Chip Break Drill Cycle
G81 Longitudinal Grooving Cycle (Turn)
G82 Face Grooving Cycle
G83 Longitudinal Thread Cycle, Plunge
G84 Longitudinal Thread Cycle, Compound
G85 Face Thread Cycle, Plunge
G86 Face Thread Cycle, Compound
G87 Tapping Cycle
G88 Boring
G90 Absolute Programming
G91 Incremental Programming
G92 Absolute Zero Preset
G94 Per Minute Feed
G95 Per Revolution Feed
G96 Constant Surface Speed Function (CSS)
G97 Revolutions Per Minute (RPM)
