Complete Bridgeport G code list for cnc machinists who work on cnc mill.
Bridgeport Mill G Codes
G code | Description |
G00 | Rapid traverse (Programmed feedrate remains in register) |
G01 | Linear interpolation (Feed in a linear path) |
G02 | Circular interpolation CW. Arc |
G03 | Circular interpolation CCW. Arc |
G04 | Dwell |
G08 | MODAL Deceleration override OFF |
G09 | MODAL Deceleration override ON |
G12 | Helical interpolation CW |
G13 | Helical interpolation CCW |
G17 | X Y Plane selection |
G18 | ZX Plane selection |
G19 | YZ Plane selection |
G22 | Circular interpolation, Fillet input CW |
G22 | Circular interpolation, Fillet input CCW |
G30 | Mirror image OFF (Cancel symmetry) |
G31 | Mirror image X ON (X symmetry) |
G32 | Mirror image Y ON (Y symmetry) |
G40 | Cancel compensation (Cutter diameter offset OFF) |
G41 | Cutter compensation left |
G42 | Cutter compensation right |
G44 | Cutter compensation, Normal feedrate |
G45 | Cutter compensation, Modify feedrate |
G70 | Input inch (Select Inch dimension system) |
G71 | Input millimeter (Select metric dimension system) |
G72 | Transformation OFF (Cancel transformation) |
G73 | Transformation / Rotation, Scaling |
G74 | Multi quadrant circle input OFF |
G75 | Multi quadrant circle input ON |
G77 | Facing cycle (Zig zag mill cycle) |
G78 | Pocket milling cycle |
G79 | Bore mill cycle (Internal hole mill cycle) |
G80 | Fixed cycle cancel |
G81 | Drill cycle – Z cycle, drill (feed in, rapid out) |
G82 | Spot facing cycle (with dwell) – Z cycle, spot face (feed in, rapid out) |
G83 | Deep hole drill cycle – Z cycle, deep hole (peck, rapid out) |
G84 | Tapping cycle (need reversible tapping head) – Z cycle, tap (feed in, feed out) |
G85 | Boring cycle (use for reaming) – Z cycle, bore (feed in, feed out) |
G86 | Boring cycle – Z cycle, bore (feed in, stop-wait, rapid out) |
G87 | Chip breaking cycle (backs up .05 then returns .05) – Z cycle, chip break (peck, rapid out) |
G89 | Boring cycle – Z cycle, bore (feed in, dwell, feed out) |
G90 | Absolute programming (Absolute input) |
G91 | Incremental programming (Incremental input) |
G92 | Preset part programming zero point |
G96 | Restore base part programming coordinate system |
G97 | Set work coordinate system |
G99 | Deceleration override |
G170 | Outside frame mill |
G171 | Inside frame mill |
G172 | Pocket frame mill |
G173 | Outside face mill |
G174 | Inside face mill |
G175 | Outside circle mill |
G176 | Inside circle mill |
G177 | Pocket circle mill |
G179 | Slot mill |
G181-G189 | Z cycle (same as g81-g89) multi-hole |
G191-199 | Z cycle (same as g81-g89) frame of holes |
