Centroid Alarm 451 Current brake applied
Cause & Effect
Overcurrent spike was detected on the drive.
Action
Usually this error condition is innocuous even if this message occurs every once in a while in a job. However, if this message occurs too often, it may mean you need a higher current drive. But, if this message appears in a continuous stream, something is seriously wrong, and you should hit E-Stop to cut power to the drive and then contact your dealer.
