A complete list of Centroid CNC lathe G Code.
A given line of a program may contain more than one G-code.
If several G-codes from one group are used in the same line, only the G-code specified last will remain active.
Centroid CNC Lathe
Centroid Lathe Operator’s Manual
CNC machinists can freely download Centroid Lathe Operator’s Manual from Centroid website
CENTROID CNC Programming Operating Manuals Free Download
Centroid CNC Lathe G Code
G Code Description
G00 Rapid Positioning
G01 Linear Interpolation
G02 Circular or Helical Interpolation CW
G03 Circular or Helical Interpolation CCW
G04 Dwell
G10 Parameter Setting
G20 Select Inch Units
G21 Select Metric Units
G22 Work envelope on
G23 Work envelope off
G28 Return to Reference Point
G29 Return from Reference Point
G30 Return to Secondary Reference Point
G32 Constant Lead Thread Cutting
G40 Cutter Diameter Compensation Cancel
G41 Cutter Diameter Compensation Left
G42 Cutter Diameter Compensation Right
G50 Coordinate System Setting, Max. Spindle Speed Setting
G52 Offset Local Coordinate System
G53 Rapid Position in Machine Coordinates
G54 Select Work Coordinate System #1
G55 Select Work Coordinate System #2
G56 Select Work Coordinate System #3
G57 Select Work Coordinate System #4
G58 Select Work Coordinate System #5
G59 Select Work Coordinate System #6
G65 Call Macro
G70 Finishing Cycle
G71 Stock Removal in Turning
G72 Stock Removal in Facing
G74 End Face Peck Cutting
G75 Outer/Inner Diameter Peck Cutting Cycle
G76 Multi-Pass Threading Cycle
G80 Cancel Canned Cycle
G83 Deep Hole Drilling
G84 Tapping
G85 Boring Cycle
G90 Outer/Inner Diameter Cutting Cycle
G92 One-Pass Threading Cycle
G94 End Face Cutting Cycle
G96 Constant Surface Speed
G97 Constant Surface Speed Cancel
G98 Per Minute Feed
G99 Per Revolution Feed
