A complete list of Centroid M-Series G Code (CNC Mill).
A given line of a program may contain more than one G-code.
If several G-codes from one group are used in the same line, only the G-code specified last will remain active.
Centroid G Code M-Series
Centroid M-Series Operator’s Manual
CNC machinists can freely download Centroid M-Series Operator’s Manual from Centroid website
CENTROID CNC Programming Operating Manuals Free Download
G-code Description
G00 Rapid Positioning
G01 Linear Interpolation
G02 Circular or Helical Interpolation CW
G03 Circular or Helical Interpolation CCW
G04 Dwell
G09 Decelerate and Stop (formerly known as Exact Stop)
G10 Parameter Setting
G17 Circular Interpolation Plane Selection XY
G18 Circular Interpolation Plane Selection ZX
G19 Circular Interpolation Plane Selection YZ
G20 Select Inch Units
G21 Select Metric Units
G22 Work envelope on
G23 Work envelope off
G28 Return to Reference Point
G29 Return from Reference Point
G30 Return to Secondary Reference Point
G40 Cutter Compensation Cancel
G41 Cutter Compensation Left
G42 Cutter Compensation Right
G43 Tool Length Compensation (+)
G43.3 Tool Length Compensation (+) with Axis Tilt Compensation
G44 Tool Length Compensation (-)
G49 Tool Length Compensation Cancel
G50 Scaling/Mirroring Off (Optional)
G51 Scaling/Mirroring On (Optional)
G52 Offset Local Coordinate System Origin
G53 Rapid Position in Machine Coordinates
G54 Select Work Coordinate System #1
G55 Select Work Coordinate System #2
G56 Select Work Coordinate System #3
G57 Select Work Coordinate System #4
G58 Select Work Coordinate System #5
G59 Select Work Coordinate System #6
G61 Modal Decel and Stop (formerly known as Exact Stop Mode)
G64 Smoothing mode selection / Cancel Modal Decelerate and Stop
G65 Call Macro
G68 Coordinate Rotation on
G69 Coordinate Rotation off
G73 High Speed Peck Drilling
G74 G Counter Tapping
G76 Fine Bore Cycle
G80 Canned Cycle Cancel
G81 Drilling and Spot Drilling
G82 Drill with Dwell
G83 Deep Hole Drilling
G84 Tapping
G85 Boring
G89 Boring with Dwell
G90 Absolute Positioning Mode
G91 Incremental positioning Mode
G92 Set Absolute position
G93 Inverse Time On
G93.1 Velocity Scrubber for Smoothed Inverse Time Data
G94 Inverse Time Off
G98 Initial Point Return
G99 R Point Return
G117 Rotation of Plane Selection XY
G118 Rotation of Plane Selection ZX
G119 Rotation of Plane Selection YZ
G173 Compound High Speed Peck Drilling
G174 Compound Counter Tapping
G176 Compound Fine Bore Cycle
G180 Compound Canned Cycle Cancel
G181 Compound Drilling and Spot Drilling
G182 Compound Drill with Dwell
G183 Compound Deep Hole Drilling
G184 Compound Tapping
G185 Compound Boring
G189 Compound Boring with Dwell
