Here is another cnc programming example, this cnc programming example shows the use of G71 Canned Cycle and G70 for Fanuc CNC Control.
Contents
G71 Turning Cycle
Although I already have posted about the G71 Turning Canned Cycle(Rough Turning Cycle), but that blog post just illustrates the use of G71 and G71 parameters.
This cnc programming example shows a complete contour cutting with G71 and finish cut on contour with G70.
G70 finishing cycle for fanuc cnc control can also be used with G72 Facing cycle for fanuc control. Usage of G70 Finishing cycle with G72 Facing cycle is same as shows here in the following example.
Program Example
CNC Programming Example with Fanuc G71 Rough Turning Cycle and G70
N10 G00 G90 X142 Z171 N20 G71 U4 R1 N30 G71 P40 Q110 U4 W2 F0.3 N40 G00 X40 N50 G01 Z140 F0.2 N60 G01 X60 Z110 N70 G01 Z90 N80 G01 X100 Z80 N90 G01 Z60 N110 G01 X140 Z40 N120 G70 P40 Q110 N130 G00 X200 Z220 N140 M30
