Fanuc Alarm 15 TOO MANY AXES COMMANDED
Fanuc Alarm Description
M Series:
An attempt was made to move the machine along the axes, but the number of the axes exceeded the specified number of axes controlled simultaneously. Modify the program.
T Series:
An attempt has been made to move the tool along more than the maximum number of simultaneously controlled axes. Alternatively, no axis movement command or an axis movement command for two or more axes has been specified in the block containing the command for skip using the torque limit signal (G31 P99/98). The command must be accompanied with an axis movement command for a single axis, in the same block.
Applies to
Fanuc CNC Controls
  • 21 Model B
