Fanuc Alarm 195 MODE CHANGE ERROR
Fanuc Alarm Description
Switching command to contouring mode, Cs axis control or rigid tap mode or switching to spindle command mode is not correctly completed. (This occurs when the response to switch to the spindle control unit side with regard to the switching command from the NC is incorrect. This alarm is not for the purposes of warning against mistakes in operation, but because continuing operation in this condition can be dangerous it is a P/S alarm.)
Applies to
Fanuc CNC Controls
- 21 Model B
