Fanuc Alarm 225 SYNCHRONOUS/MIXED CONTROL ERROR
Fanuc Alarm Description
T series (At two–path)
This alarm is generated in the following circumstances. (Searched for during synchronous and mixed control command.
1 When there is a mistake in axis number parameter (No. 1023) setting.
2 When there is a mistake in control commanded. During hobbing synchronization, a command to bring the C–axis under synchronous, composite, or superimposed control is made. Modify the program or the parameter.
