Fanuc Alarm 37 CAN NOT CHANGE PLANE IN CRC
Fanuc Alarm Description
M seires
G40 is commanded on the plane other than offset plane in cutter compensation B. The plane selected by using G17, G18 or G19 is changed in cutter compensation C mode. Modify the program.
T Serires
The offset plane is switched in tool nose radius compensation. Modify the program.
Applies to
Fanuc CNC Controls
  • 21 Model B
