Fanuc Alarm 511 OVER TRAVEL: –n
Fanuc Over travel Alarm Description
Alarm for stroke check prior to movement. The end point specified in a block falls within the forbidden area defined with the stroke check in the negative direction along the N axis. Correct the program.
