Fanuc Alarm PS062 ILL COMMAND IN G70–G76
Fanuc Alarm Description
Fanuc 10/11/12/15
The value specified by address D in a G71, G72, or G73 block is zero or negative.
The value specified by address K or D in a G76 block is zero or negative, or the value specified by address A is out of bounds (valid range: 0° A° 120°).
The value specified by I, K, or D in a G74 or G75 block is negative.
X is specified even though the value specified by I in a G74 or G75 block is zero, or Z is specified even though the value specified by K is zero.
