Fanuc Alarm PS076 PROGRAM NOT FOUND
Fanuc Alarm Description
Fanuc 15i
The specified program is not found in the subprogram call, macro call or graphic copy.
The M, G, T or S codes are called by a P instruction other than that in an M98, G65, G66, G66.1 or interrupt type custom macro, and a program is called by a No. 2 auxiliary function code.
This alarm is also generated when a program is not found by these calls.
Fanuc 10/11/12/15
The program indicated by the program No. called by M98, G65, G66, G66.1, or a G, M, or T code could not be found.
