Fanuc Alarm PS187 FEED ZERO (COMMAND)
Fanuc Alarm Description
Fanuc 10/11/12/15/15i
The cutting feedrate instructed by an F code has been set to 0. This alarm is also generated if the F code instructed for the S code is set extremely small in a rigid tapping instruction as the tool cannot cut at the programmed lead.
