Fanuc Alarm PS272 CRC: INTERFERENCE
Fanuc Alarm Description
Fanuc 15i
The depth of the cut is too great during cutter compensation. Check the program.
The criteria for judging interference are as follows:
(1) The direction of movement of the programmed block differs from the direction of movement of the corresponding tool center path block by 90° or more or 270° or less. The check in this case can be disabled by setting CNC parameter No. 6001#1 to “1”.
(2) In the case of an arc, the difference in angle between the start and end points of the programmed block differs by 180° or more with the difference in angle between the start and end points of the corresponding tool center path block.
Fanuc 10/11/12/15
The depth of cut is too great while offset C is in effect.
