Fanuc Alarm PS429 MISSING VALUE AT CNR, CHF
Fanuc Alarm Description
Fanuc 15i
The specified movement distance is less than the specified chamfering or cornering amount in a block in which chamfering or cornering is specified.
Review the program instructions.
Fanuc 10/11/12/15
The specified movement distance is less than the specified cornering or chamfering amount in a block in which chamfering or cornering is specified.
Mill – When a block with cornering or chamfering was inserted, the original movement command range was exceeded.
