Fanuc Alarm PS581 ENCODE ALARM (PARAMETER)
Fanuc Alarm Description
Fanuc 15i
When an attempt was made to punch an encrypted tape, the punch code parameter was set to EIA. Set EIA parameter No. 0#4 to “0”.
An incorrect instruction was specified for program encryption or protection. This alarm is also generated when the protected range is edited or deleted in a program–locked state.
The protected range is defined from the program No. preset by parameter No. 2212 up to the program No. preset to parameter No. 2213. When both parameters are set to “0”, the protected range becomes O9000 to O9999.
Fanuc 10/11/12/15
When an attempt was made to punch an encrypted tape, the punch code parameter was set to EIA. An incorrect command was specified for program encryption or protection.
