Fanuc Alarm PS895 ILLEGAL PARAMETER IN G02.3/G03.3
Fanuc Alarm Description
Fanuc 15i
The parameter setting that specifies the axis on which to execute exponential interpolation is incorrect.
Parameter No. 7636: Linear axis No. on which exponential interpolation is executed
Parameter No. 7637: Axis of rotation No. on which exponential interpolation is executed
The setting is 1 to the number of controlled axes. The same axis Nos. must not be set.
Fanuc 15
The setting (parameter No. 7636) that specifies the axis for which to perform exponential interpolation is incorrect.
Fanuc 10/11/12
There is an error in the setting of the axis (Parameter number 7636, 7637) for performing the exponential function interpolation.
