Fanuc Alarm SR160 COMMAND DATA OVERFLOW
Fanuc Alarm SR160 INTERNAL DATA OVER FLOW
Fanuc Alarm Description
Fanuc 15i
An overflow in the CNC internal positional data occurred. This error is also generated when the target position exceeds the maximum stroke as a result of calculating coordinate conversion, offset and manual intervention compensation inputs.
Fanuc 15
Coordinates specified in an absolute or machine coordinate system are out of range.
In general, this alarm is generated when the rotational axis is rotated a number of times and an absolute coordinate becomes greater than +99999.999 or less than –99999.999 (for increment system IS–B).
Perform reference position return when this alarm occurs.
