Fanuc Alarm SR600 PARAMETER OF RESTART ERROR
Fanuc Alarm Description
Fanuc 15i
An illegal value is set to parameter No. 7110 that specifies the order in which axes move when machining is restarted in the dry run.
The setting range is 1 to the number of controlled axes.
Fanuc 10/11/12/15
There is an error in the specification of the program restart parameter.
