Complete list of GSK 980TDb G Codes
GSK 980TDb – Turning CNC System
GSK 980TDb G Codes
G Code | Meaning |
G01 | Linear interpolation |
G00 | Rapid traverse movement |
G02 | Circular interpolation(CW) |
G03 | Circular interpolation(CCW) |
G04 | Dwell time preset |
G05 | Three-point circular interpolation |
G6.2 | Ellipse interpolation (CW) |
G6.3 | Ellipse interpolation (CCW) |
G7.1 | Cylinder interpolation |
G7.2 | Parabola interpolation (CW) |
G7.3 | Parabola interpolation (CCW) |
G10 | Data input |
G11 | Data input cancel |
G12.1 | Polar coordinate interpolation |
G13.1 | Polar coordinate interpolation cancel |
G17 | XY plane |
G18 | ZX plane |
G19 | YZ plane |
G20 | Inch select |
G21 | Metric select |
G28 | Machine reference point automatic return |
G30 | Machine 2nd, 3rd , 4th reference point |
G31 | Skip interpolation |
G32 | Thread cutting |
G32.1 | Rigid thread cutting |
G33 | Z tapping cycle |
G34 | Variable pitch thread cutting |
G36 | Automatic tool compensation X |
G37 | Automatic tool compensation Z |
G40 | Cancel cutter radius compensation |
G41 | Tool nose radius compensation left contour |
G42 | Tool nose radius compensation right contour |
G50 | Setting workpiece coordinates system |
G65 | Macro command |
G70 | Finishing cycle |
G71 | Axial roughing cycle |
G72 | Radial roughing cycle |
G73 | Closed cutting cycle |
G74 | Axial grooving cycle |
G75 | Radial grooving cycle |
G76 | Multiple thread cutting cycle |
G84 | End rigid tapping |
G88 | Side rigid tapping |
G90 | Axial cutting cycle |
G92 | Thread cutting cycle |
G94 | Radial cutting cycle |
G96 | Constant surface speed ON |
G97 | Constant surface speed OFF |
G98 | Feed per minute |
G99 | Feed per rev |
