Alarm: 103 X SERVO ERROR TOO LARGE
Load on X-axis Servomotor has exceeded parameter 9 X-axis Max Error. Servos are turned off and you must push RESET to clear the alarm and turn on the servos. Dull cutting tools or an incorrect program is exceeding the Max Load for this axis. Lathe: Servo brake on X axis motor may not be disengaging. 24VDC is needed to release brake. Servo brake power is supplied from Trans/Brake PCB P5/P9, or on I/O PCB P78/P79 when servos are powered on. Verify power to hydraulic card.
