Haas Alarm: 107 EMERGENCY OFF
Emergency Stop button was pressed. Servos are also turned off. After the E-Stop is released, the Reset button must be pressed at least twice to correct this; once to clear the E-Stop alarm and once to clear the Servo Off alarm. This alarm will also be generated if there is a low pressure condition in the hydraulic counterbalance system. In this case, the alarm will not reset until the condition has been corrected.
