Haas Alarm: 114 TURRET LOCK FAULT – Haas Lathe
The turret took longer to lock and seat than allowed for in Parameter 63. The value in Parameter 63 is in milliseconds. This may occur if the air pressure is too low, the tool turret clamp switch is faulty or needs adjustment, or there is a mechanical problem. If the Turret has not rotated to the correct position, the motor coupling may need adjustment. Debris between the male and female turret couplings can prevent the turret from locking completely.
