Haas Alarm: 116 SPINDLE ORIENTATION FAULT
Spindle did not orient correctly. During a spindle orientation function, the spindle rotated but never achieved proper orientation. This can be caused by failure of encoder, cables, belts, MOCON or vector drive. Parameter 257 Spindle Orient Offset may not be set correctly, causing misalignment with toolchangers.
