Alarm: 126 GEAR FAULT
Gearshifter is out of position when a command is given to start a program or rotate the spindle. This means that the two speed gear box is not in either high or low gear but is somewhere in between. Check the air pressure, the solenoid’s circuit breaker CB4, and the spindle drive. Use the Power Up/Restart button to correct the problem.
