Alarm: 128 SUPER TRAVEL ENABLED ON MULTIPLE AXES
Two or more axes are enabled for super travel. Only one axis is allowed super travel capability. Super travel is enabled when a tool change offset parameter is greater than or less than normal travel limits. Check the Zero Axis TC, Max Travel, and Tool Change Offset parameter values for the X and Y axes.
