Alarm: 129 M FIN FAULT
M-Fin was active at power on. Check the wiring to your M code interfaces. This test is only performed at power-on. Parameter 734 bit M-CODE FINISH may be inverted.
- Haas Parameter 734 (L) INPUT MASK (Used for the Office Lathes)
- Haas Parameter 734 (M) INPUT MASK (Used for the Office Mills)
