Haas Alarm: 131 TOOL NOT CLAMPED – Haas Mill
NOT CLAMPED – When clamping or powering up the machine, the Tool Release Piston is not Home. Check TRP switches for correct operation and adjustment. There is a possible fault in the air solenoids, relays on the I/O Assembly, drawbar assembly, or wiring.
