≡ MENU
Home
Fanuc
Learn
Examples
Sinumerik
Haas
Reference
Alarms
About
Haas
Haas How To?
Manuals
Mill Manual
Lathe Manual
G & M Codes
G Codes Mill
M Codes Mill
G Codes Lathe
M Codes Lathe
Alarms
Haas Alarms
Settings
Mill Settings
Lathe Settings
Haas Parameters
Mill Programming
G70 Bolt Hole Circle
G71 Bolt Hole Arc
G72 Bolt Hole Angle
G83 Peck Drilling Cycle
G84 Tapping Cycle
Lathe Programming
G10 Programmable Offset
G71 Roughing Cycle
G76 Threading Cycle
G73 Pattern Repeating
C-Axis
Subprogramming
M Code Tutorials
M19 Spindle Orientation
M97 Local Sub-Program
M98 Subprogram Call
M99 Subprogram Return
Haas Alarm: 148 A LIMIT SWITCH
Alarm:
148 A LIMIT SWITCH
Normally disabled for rotary axis.
