Haas Alarm: 238 AUTOMATIC DOOR FAULT – Haas Mill
The automatic door was commanded to operate, but did not complete
the operation. The door was:
1) Commanded to close but failed to contact the closed switch in the time allowed.
2) Commanded to open but failed to contact opened switch (not all doors have switch) in time allowed.
3) Commanded to open but did not begin moving in the time allowed. Check door switch, door for mechanical binding, and that the door motor and clutch are functioning correctly.
