Alarm: 267 TOOL DOOR OUT OF POSITION – Haas Mill
This alarm will be generated on a horizontal mill during a tool change when Parameter 278, TL DR Switch is set to 1, and the tool carousel air door switch indicates that the door is open after it was commanded closed, or closed after it was commanded open. This alarm will most likely be caused by a stuck or broken switch.
