Alarm: 298 ATC DOUBLE ARM OUT OF POSITION – Haas Mill
ATC double arm mark switch, or CW/CCW position switch is in an incorrect state. Check for sticking, misaligned or damaged switches, mechanism binding, damaged motor, or debris build up. Use Tool Changer Restore to recover the ATC, then resume normal operation.
