Alarm: 332 H AND T NOT MATCHED – Haas Mill
This alarm is generated when Setting 15 is turned ON. An H code number in a running program does not match the T number in the spindle. Correct the H codes, select the right tool, or turn off Setting 15 to run programs don’t have corresponding H and T codes.
