Alarm: 447 SERVO BAR BAR IN WAY – Haas Lathe
The end of bar switch was depressed and a load or unload bar was commanded. Remove the bar. Check the function of the switch in diagnostics display. End of Bar Switch input should normally be 0, then change to 1 when depressed.
