Alarm: 613 COMMAND NOT ALLOWED IN CUTTER COMPENSATION
At least one command in the highlighted block cannot be executed while cutter compensation is active. Block Delete characters (‘/’) are not allowed. Your program must have a G40 and a cutter compensation exit move before these can be commanded.
