Alarm: 614 V SERVO OVERLOAD – Haas Mill
Excessive load on V-axis motor. This can occur if the load on the motor over a period of several seconds or even minutes is large enough to exceed the continuous rating of the motor. The servos will be turned off when this occurs. This can be caused by running into the mechanical stops or by anything that causes a very high load on the motors.
