Alarm: 640 APC-MISSING PALLET @ REC – Haas Mill
Pallet change sequence halted because receiver switch not activated. Pallet either unclamped or not on receiver. Ensure pallet is correctly located on receiver (against hard stop), then run M18 to clamp the pallet. After correcting the condition, run M50 to continue machining.
