Haas Alarm: 661 U TRANSITION FAULT – Haas Mill
Illegal transition of count pulses in U-axis. This alarm usually indicates that the encoder has been damaged and encoder position data is unreliable. This can also be caused by loose MOCON or MOTIF PCB connectors.
