Alarm: 668 V AXIS LINEAR SCALE Z FAULT – Haas Mill
Encoder marker pulse count failure. This alarm usually indicates that the Z Fault encoder has been damaged and encoder position data is unreliable. This can also be caused by loose scale connectors.
