Haas Alarm: 698 ATC PARAMETER ERROR – Haas Mill
The ATC type cannot be determined. Check Parameter 278, bit 10, HS3 HYD TC, or Parameter 209, bit 2, Chain TC, as appropriate for the installed tool changer. Use Tool Changer Restore to recover the ATC, then resume normal operation.
