Alarm: 701 U SERVO ERROR TOO LARGE MOCON2 – Haas Lathe
Too much load or speed on U-axis motor. Difference between motor position and commanded position has exceeded Parameter 362. The motor may also be stalled, disconnected, or the driver failed. The servos will be turned off and a Reset must be done to restart. This alarm can be caused by problems with the driver, motor, or the slide being run into the mechanical stops.
