Alarm: 708 S SERVO ERROR TOO LARGE MOCON2 – Haas Lathe
Too much load or speed on S-channel motor. Difference between motor position and commanded position has exceeded a parameter. The motor may also be stalled, disconnected, or the driver failed. The servos will be turned off and a Reset must be done to restart. This alarm can be caused by problems with the driver, motor, or the slide being run into the mechanical stops.
