Haas Alarm: 713 W SERVO OVERLOAD MOCON2 – Haas Lathe
Excessive load on W-axis motor. This can occur if load on the motor over a period of several seconds or even minutes is large enough to exceed the continuous rating of the motor. The servos will be turned off when this occurs. This can be caused by running into the mechanical stops but not much past them. It can also be caused by anything that causes a very high load on the motors.
