Haas Alarm: 782 V TRANSITION FAULT – Haas Lathe
Illegal transition of count pulses in bar feeder. This alarm usually indicates that the encoder has been damaged and encoder position data is unreliable. This can also be caused by loose connectors at the MOCON or MOTIF printed circuit board.
