Alarm: 808 AUTOMATIC PROBE ARM FAULT
Automatic probe arm failed to complete command to extend or retract. Check for tools or parts in machining area that block motion of probe arm. Check for sufficient air pressure and volume. Check probe arm mechanism for broken parts, damaged air lines, or broken electrical connections. After resolving problem, command the probe arm to the home position and continue operation.
