Alarm: 971 FAILED LOAD
The on board device computer failed to load network drivers. This is from an invalid network setting. Cycle power. CNC should go into Drivers not Loaded mode, change network settings and try again. If you continuously get Failed to Load alarms without Drivers not Loaded mode, notify your dealer. The default network settings can be restored if needed. Press Prgrm Convers during power up, then Press P Enter, then P5 Enter.
