Alarm: 996 TAIL STOCK MUST BE ZERO RETURNED – Haas Lathe
The hydraulic tail stock has been adjusted to a new position. The B-axis must be zero returned before the tailstock can be used. Ensure that the correct lock bolt is securely tightened before pressing the zero return key. It is highly recommended that settings 93 and 94 be adjusted for the new tailstock position.
