Haas Parameter 11 X TORQUE PRELOAD – Haas Mill
Torque Preload is a signed number that should be set to a value from 0 to 4095, where 4095 is the maximum motor torque. It is applied at all times to the servo in the same direction. It is used to compensate, in the vertical direction, for gravity on a machine with an axis brake instead of a counterbalance. Normally, the brake is released when the servo motors are activated. When the vertical axis is commanded to move, the brake is released and the servo motors are activated. This parameter specifies the bias torque compensation for gravity.
