Haas Parameter 180 Sp SLIP GAIN
Calculated slip rate depends on two other variables: speed and current. Slip rate = slip gain x (speed/max speed) x (current/max current). The slip gain value is the value that slip rate would assume at maximum speed, and maximum current (16.384 =1 Hz).
